1990 Buick Riviera no crank when ignition is turned
98,000 MILES • 6 CYL • FWD • AUTOMATIC
INSTALLERROYAL
My car was working fine and then all of a sudden I could not start the car. This has happened once before when I could not get the car to start. It would crank but would not start, so I disconnected the battery for a while ,shortly after I then reconnected the battery and the car started just fine. I have believed that there was a problem with the factory security system. Could you please help. Thanks in advance.
Jan 25, 2008 at 10:47 AM
BMRFIXIT
  • 19,053 POSTS
[quote:44d9d92afe="installerroyal"]Electrical problem
1990 Buick Riviera 6 cyl Front Wheel Drive Automatic 98000 miles
My car was working fine and then all of a sudden I could not start the car. This has happened once before when I could not get the car to start. It would crank but would not start, so I disconnected the battery for a while ,shortly after I then reconnected the battery and the car started just fine. I have believed that there was a problem with the factory security system. Could you please help. Thanks in advance.[/quote:44d9d92afe]
it say no crank
check the starter
check battery + terminals
check neutral safety switch
check alarm system
Jan 27, 2008 at 12:45 PM
