can not any action to the rear brakes when pressing the brake pedal. Seems like it takes more power to press the pedal and less braking power.
Jan 22, 2008 at 10:36 AM
2CARPRO JACK
✓Experienced Mechanic
SOunds like th epower booster is having aproblem. Verify good vacuum to it and be sure the check valve is good, If all good then it needs a new booster
Jan 23, 2008 at 7:17 AM
BIGALAN
MEMBER
[quote:138a437395="2CarPro Jack"]SOunds like th epower booster is having aproblem. Verify good vacuum to it and be sure the check valve is good, If all good then it needs a new booster[/quote:138a437395]
