1989 Buick Riviera Touch screen
250,000 MILES • 6 CYL • FWD • AUTOMATIC
DOUGLAS HALL
I need help getting my touch screen computer to display again. Occasionally it will flicker on, but generally it stays black. I still have full funtion I just can't see anything. Please help me diagnose if you can. Thank you.
Douglas Hall
Jul 30, 2010 at 9:27 AM
RGFULLERTON
The actual display CRT is bad. These are custom input conventional CRT displays that can only be repaired by an electronic Tech. These displays were actually made by ZENITH. I had the same issue but just popped my 1986 CRT into my 89.They are very easy to change. I can buy one at the local junk yard for around $40. Intresting factoid - These displays are upwordly interchangeable BUT NOT DOWNWARD. A 1986, 87, 88 display will work in your 1989 but not the other way!
Aug 20, 2010 at 7:57 AM
