1989 Buick Riviera overheats
1989 BUICK RIVIERA
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUSTY BAKER
My cooling fans don't come on when they should. Have replaced the heat sensor and all fan relays. Both fans have been tested and do work, The thermostat seems to open okay. Don't know what to check or replace.
Oct 8, 2009 at 8:12 PM
DOCFIXIT
  • 18,828 POSTS
The ECM grounds relays in response to temp and AC input. So if relays not clicking in and power is there then ECM or wiring is at fault.
Oct 9, 2009 at 10:46 AM
