2003 Buick Rendezvous Cylinder 5 Misfire
FAMILYGAL
I have a 2003 buick Rendevezous it has a 3.4 motor with 81451 mileage. My computer tells me that it has 1 of 2 codes in it cylinder 5 misfires, I had cylinder 5 plug, wire and coilpack replaced ant it still keeps giving me the same code. It also idles irratically especially when I come to a red light it I let the rpm's go below 1 1/2 the motor will die, but whenever you get up to speed you cannot feel it idle funny. It is driving me cracy. I need help with this issue. Someone told me I need a new motor could someone please tell me or at least help me with this problem
Oct 14, 2007 at 7:04 AM
  • 55,859 POSTS
Hey Familygal,
It sounds like it could be one of two problems, first it could be low compression which you will need to test, the next problem it could be is the injector, here are two guides which you can use to help you find the problem.
and
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please let us know happens so it will help others.
Best, Ken
Nov 29, 2016 at 9:58 AM
Suggested Repair
With the cylinder 5 plug, wire, and coil pack already replaced, test engine compression and the cylinder 5 fuel injector before considering an engine replacement.
Conversation Summary
A 2003 Buick Rendezvous with a 3.4L engine has a persistent cylinder 5 misfire after the plug, wire, and coil pack were replaced. It idles erratically and can stall when RPM drops at a stop, but runs normally at speed. The expert recommends testing compression and the fuel injector rather than assuming a new engine is needed.
