2002 Buick Rendezvous Electrical Issues
YAKEMY
the alarm, horn, door locks, front light flashes, air stops working, the dash board reading goes crazy and wont stop, usualy does this in the afternoon after i get out of work, the vehicle goes crazy alway in the afternoon the only change i did to the vehicle was changing the radio, 2002 buick rendenzvous mileage over 114100 3.4 engine
May 11, 2007 at 1:48 PM
DENNYP
  • 1,824 POSTS
[quote:eb2c0605a9="yakemy"]the alarm, horn, door locks, front light flashes, air stops working, the dash board reading goes crazy and wont stop, usualy does this in the afternoon after i get out of work, the vehicle goes crazy alway in the afternoon the only change i did to the vehicle was changing the radio, 2002 buick rendenzvous mileage over 114100 3.4 engine[/quote:eb2c0605a9]sounds like the body control module is toast.very common on theese vehicles.
Sep 27, 2007 at 4:55 PM
Suggested Repair
Have the body control module tested and replaced if faulty. BCM failure is common on these vehicles and can cause the alarm, horn, locks, lights, HVAC, and erratic dash readings.
Conversation Summary
The owner of a 2002 Buick Rendezvous with over 114,100 miles reports afternoon electrical problems: the alarm, horn, door locks, and front lights act up, the air stops working, and the dashboard readings go crazy. The only recent change was a radio replacement. The expert says the body control module is likely failed, a common problem on these vehicles.
