Accelerating & reving and NOT using gas pedal.
AYOVANOVICH
04 Buick Rendevous, 82k. Base model.
Accelerating and not using gas pedal. While in neutral and Park & it sounds like it's revving, but the RPM's are not going up. Turned off & turned back on, revving went away (briefly) but then continued to accelerate on own.
Help!
Aug 6, 2007 at 1:27 PM
CLY
  • 308 POSTS
If you have a vacumm leak it could cause a high idle. Any check engine lights or anything on?
Cly
Aug 6, 2007 at 1:31 PM
AYOVANOVICH
not a thing.
I noticed the change about an hour ago, I was pulling out of a parking lot & put it in reverse. It shifted hard & then this started.
Thanks for your insight.
A
Aug 6, 2007 at 1:40 PM
