Why is my brake pedal pulsating?
22,000 MILES • 6 CYL • FWD • AUTOMATIC
MR. MAGOO 99
what causes front brakes to occasionally pulse and vibrate?
Oct 6, 2009 at 11:29 AM
Sounds like the ABS may be activating. If the pedal does not vibrate all the time when you press it then this is not a brake pulsation due to warped rotors.
If this is happening on dry roads then we need to start with scanning for ABS codes. Here is a guide that will help with this:
https://www.youtube.com/watch?v=rTtAnsOlZU4
Depending on the codes we will have a better idea but the most likely cause of this is either a speed sensor issue or an ABS module issue.
I attached the info below on this but let's start with the codes and go from there. Thanks
Mar 9, 2021 at 11:29 AM
