2006 Buick Rendezvous Starting/ occasionally
16,300 MILES • 6 CYL • FWD • AUTOMATIC
CLAIR MCCURDY
When starting , occasionally, the starter continues to operate after engine has engaged or started. Not for long but it is pronounced. I am not sure that it is the starter but that is the only explanation I have for this problem.
Feb 8, 2008 at 2:37 AM
STEVE38
I have an 06 Rendezvous also, and the car is supposed to do this. Higher end cars have had this feature for quite some time and I was suprised to find it in a mid level Buick. When you turn the key, the car automatically takes over and continues to turn the engine over until it starts or 5-7 seconds go by. Usually the car starts by this time unless there is a problem. This is a normal feature in and of itself and does not present a problem. GM has had this feature standard on Cadillac, Olds Aurora, mostly the high end stuff. They have been filtering this feature down.
Aug 29, 2008 at 5:09 PM
