2006 Buick Rendezvous Ignition switch
50,500 MILES • 6 CYL • AWD • AUTOMATIC
ALBOB13
The ignition switch foes not turn and the steering wheel does not lock
Jan 21, 2009 at 10:58 AM
  • 110,251 POSTS
Hi:
If the key doesn't turn, the tumbler may be bad. I have even see cases where the key was worn to a point it would no longer work. Try a different key if you have one. let me know what happens.
Jan 21, 2009 at 11:54 AM
ALBOB13
I have tried both keys and neither works. The steering wheel is not locked either. I am afraid the transmission may not be in park, but with out the ignition switch being able to turn the shifter can not be moved either.
Jan 21, 2009 at 12:08 PM
  • 110,251 POSTS
If you were able to remove the key the last time it worked, it should be in park. With everything you described, it truly sounds like the tumbler assembly needs replaced.
Jan 22, 2009 at 6:14 AM
