2006 Buick Rendezvous Cruse Contol Problem
76,980 MILES • 6 CYL • FWD • AUTOMATIC
DANDAMAN
In the past when the car hit a bump the cruse control would disengage. Sometimes it would not engage.Later it would work ok. Now the cruse cintrol will not engage regardless of the speed.
Nov 28, 2009 at 3:27 PM
MERLIN2021
  • 17,250 POSTS
Two things we need to know, engine size?
And can you get it scanned for codes? Autozone does it free write down codes and post with engine size, there are two different systems depending on engine.
Nov 28, 2009 at 11:40 PM
DANDAMAN
engine 3.5
no code appear in on board computer check
Cruse control no longer engages regardless of speed.
Nov 29, 2009 at 2:58 PM
MERLIN2021
  • 17,250 POSTS
Check to see if the brake lights work, and if the transmission range switch, or old term neutral saftey switch, how good are you with testing automotive circuits? Have a test light and DVOM?
Nov 30, 2009 at 5:56 AM
DANDAMAN
Brake lites work ok. I have an electronics background. Trans column switch seems ok.
What should I check. Is there a speed sensor and where.
dan
Nov 30, 2009 at 6:03 AM
MERLIN2021
  • 17,250 POSTS
Dan I sent you an email with a troubleshooting chart(3) wiring diagram, and control unit locations and diagrams, let me know how it goes!
Nov 30, 2009 at 6:18 AM
