Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Rendezvous
Interior
Cruise Control
Not Working
2006 Buick Rendezvous Cruise Control
2006 BUICK RENDEZVOUS
74,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROGER VIGAR
MEMBER
1 POST
Cruise control has stopped working, but the dash indicator light saying that it is engaged, don't known where to look next, the fuse checked OK.
Sep 25, 2009 at 5:37 AM
KHLOW2008
Experienced Mechanic
Hi Roger Vigar,
Thank you for the donation.
If the light is indicating the cruise control is ON but it is not working correctly, it should not be a fuse problem.
It could either be the control unit, cable or other wiring fault.
You would need a scan tool to diagnose the cause.
Sep 27, 2009 at 1:35 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
