2005 Buick Rendezvous gas smell
JAY IN MTL
Smells problem
2005 Buick Rendezvous Automatic 10000 miles
My 2005 Rendezvous has been leaking gas. The mechanic said that the lines need to be replaced with hard plastic ones. They ordered some but have no idea when they will arrive. I would like to help speed up the process so I can get this car back on the road.
Does anybody have any info on the model number(s) or compatible lines? Also where to look for them online?
May 31, 2010 at 12:36 PM
  • 110,248 POSTS
The brake lines should be steel if they run under the vehicle to the engine. If there is a fire, plastic will melt and then it makes things much worse.
Jun 1, 2010 at 6:47 AM
