2004 Buick Rendezvous Transmission Slipping
96,000 MILES • 6 CYL • FWD • AUTOMATIC
MARK81
Recently our Rendezvous has had a problem where when moving from park to drive or when at a stop light the car is VERY sluggish. Eventually it will take of abruptly until the next stop light. I have checked the fluid and there is enough and it doesn't smell "burnt". I have had the transmission serviced every 30,000 miles but have never had the pan pulled off. Is this a repair job for a transmission shop or will it need to be preplaced? We love the car and really want to keep it.
Thanks for any information,
Mark81
Aug 1, 2010 at 10:11 AM
  • 75,988 POSTS
If you feel the transmission is slipping bring it in and have it checked out,otherwise-see below:
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 1, 2010 at 2:57 PM
