2004 Buick Rendezvous Install satellte radio
115,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKENM
I want to power my satellte radio from same power source as the radio so when the key is turned off the unit will power off. What color wire and where is it located so I can just spice in.
Aug 7, 2010 at 12:34 PM
KHLOW2008
  • 41,812 POSTS
Hi mikenm,
Thank you for the donation.
The radio uses constant battery power to keep the memory and ths ON/OFF function when the ignition switch is turned ON/OFF is computer controlled. There is no wire that you can splice into.
You would have to get alternate source from the ACC circuit around the dash.
Aug 8, 2010 at 12:34 AM
