2004 Buick Rendezvous Fuse Problem
2004 BUICK RENDEZVOUS
77,000 MILES • 6 CYL • 2WD • AUTOMATIC
DENNIS MADONI
It seems thst the fuse is OK for my Rear Auxiliary Power Outlet. It still does not work and it seems that I have no power their.HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 10, 2010 at 7:41 AM
GMTECH
  • 537 POSTS
What you need to do is check for power at both sides of the fuse. If that is ok, check power to the rear socket. Yo have have a couple of fuses for your outlets. If you have power at the fuse but none to the socket then you most likely have a wiring issue somewhere in between.
Oct 25, 2010 at 7:35 AM
