2004 Buick Rendezvous Fuel Pump?
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIPPIN
My Rendevous will sometimes not start. It seems to happen when I stop and try to start again fairly quickly (0-15 min). it will always start after waiting about 15-30 minutes.
Took to a mechanic shop and they said they couldn't reproduce it so nothing is wrong. I seem to be able to reproduce it regularly.
Any help is appreciated.
Mar 24, 2010 at 9:52 AM
  • 75,988 POSTS
Do below don't wait for nothing something has to give here between fuel and spark and get back with me
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Mar 24, 2010 at 11:20 AM
