2004 Buick Rendezvous condenser removal
50,000 MILES • 6 CYL • AWD • AUTOMATIC
ABOLDUC
I have a leaking condenser and am in the process of replacing it. I have all connections removed but can't get the condneser out. Any ideas?
Jun 16, 2008 at 7:29 AM
LUCIDBARRIER
You have to disconnect a/c lines at the fittings (after evacuation) and remove the radiator and condenser together as a single unit. There are a couple bolts that hold the two together and are virtually impossible to reach unless you pull them out as a single unit.
Sep 20, 2008 at 8:26 PM
