2004 Buick Rendezvous Bad Bearings
101,350 MILES • 6 CYL • AWD • AUTOMATIC
MYVEHICLE
I need a step by step pictures diagram of this
area so I can get the bearing of
what stpe do I need to take to remove the bearing
and put new one on
Aug 5, 2010 at 11:12 PM
MERLIN2021
  • 17,250 POSTS
Pictures, I don't have, but remove the axle nut, remove the tire, remove the brake caliper and rotor, dont disconnect the brake hose, hang the caliper from the coil spring with wire. Remove the rotor, unplug ABS wire, remove the three bolts that secure the hub bearing the the knuckle, pull off. Install is the reverse.
Aug 6, 2010 at 1:10 AM
