I have a 2004 Buick RendezVous that after about a month or so of replacing the front brake pads it started to squeak when pushing on the brakes. It appears it is only squeaking when you first brake and as you apply more pressure it will eventually go away, but it is a HIGH PITCHED squeak. The pads are still fine and not warn and the rotors appear to be OK, but they may need replaced as well I suppose. Also, around the same time the AWD Disable light started to come on and stays on all the time as well, so I don't know if this is a related issue or not. All of the wiring for the connectors to the wheel sensors appear to be ok for the AWD computer, but it still kicks on the AWD disable light the moment you turn the car on. If you could help with either of these problems it would be appreciated since I have pretty much exhausted all of the things that i can think it would be that is causing these problems.
Sep 29, 2010 at 5:17 AM
