When I drive the car with no load it shifts fine, once I put any weight in the car the transmission will not shift out of 2nd gear. I checked the fluid level and it is fine. It shows that I have a sensor problem when I have taken it in. I would like to know if changing the sensor will fix the problem
Nov 7, 2008 at 11:23 AM
