2003 Buick Rendezvous Stripped bolt heads on rear vavle cov
130,000 MILES • 4 CYL • AWD • AUTOMATIC
JOENOLLEY
I am removing the heads on my 2003 Buick Rendezvous to replace the gaskets. I took this same car to a dealer 10 months ago and had the head gaskets replaced. My mechanic checked it the other day and said the head gaskets were blown again. I refuse to pay the dealer to fix it again, so I am doing it myself (warranty is out on the repair work). When I rolled the engine forward to acces the rear valve comver, three of the four blots are stripped. Any suggestions on how to get them out. I have tried one of those back out tools, however there is not much room in there to swing a hammer to get them on.
Dec 31, 2009 at 12:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
start by using a suitable penetration fluid, such as PB Blaster or WD40 to help you along with the removal process of the bolt. Spray the fluid around the head of the stripped bolt. You want the penetrating fluid to work its way down into the threads of the stripped bolt as you are working on it so removal will be easier. It can mean the difference between the stripped bolt coming out faster or you having to resort to more procedures to remove the bolt. Craftsman makes an excellent damaged bolt or nut removal tool that works like a vice on the head of stripped bolts and nuts. The more you tighten down on the stripped bolt, the more it bites into it and helps turn it out. You may want to try this first before resorting to drilling out the bolt. If you have to resort to drilling the stripped bolt out, you will of course need a drill and drill bits. Use a 1/4 inch drill bit in the center of the stripped bolt. Drill down about an inch. This hole will help guide the larger drill bits so drill it as straight as possible. Once you have that first hole drilled, you can start moving up in sizes with your drill bits until you have one drill bit a little smaller that the actual diameter of the hole. If you go too far you can damage the inner threads of the hole and make it near impossible to get a new bolt back in once you're finished removing the old bolt. Take your time at this stage. Once you have most of the stripped bolt drilled out, you can use a screw extractor kit to remove the bolt. This kit basically has threaded screw type heads that dig into the inside of the drilled bolt and grasps it as the bolt is being turned outwards. One of the least popular ways to repair a stripped bolt is to heat the head of the bolt. Do not use this technique when the bolt is screwed into an aluminum surface. If you heat a bolt that is in aluminum, when you go to turn the bolt after heating, you will not only remove the bolt, but also some of the aluminum surrounding the bolt. Once the bolt is removed you may want to spray the inner surface of the bolt hole with WD-40 or PB Blaster so the next time you don't start out an easy job by stripping one of your bolts. May want to consider investigating what is causing the premature failiure of those head gaskets. Obviously something is not right. Has it been showing overheating any on the temp. gauge?
Dec 31, 2009 at 12:41 PM
JOENOLLEY
Thanks. My mechanic suggested the heads need to be machined to create a flat surface. I will not drill the bolt out, that scares me. I assume the PB Blaster will also help me get the removal socket on there? The type I bought this evening has the spirals on the inside of the socket.
Dec 31, 2009 at 12:53 PM
