Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Rendezvous
Warning Lights
Service Light
2003 Buick Rendezvous service light on
2003 BUICK RENDEZVOUS
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
CSCOTT71
MEMBER
yes i get it scaned and code po453 came up and i repaced pressure sensor in the tank and unhooked the battery and drove 20 miles and came back on
Jan 4, 2009 at 12:46 PM
BLUELIGHTNIN6
Experienced Mechanic
Check volts at wiring. Should not exceed 4.9 volts or it will illuminate the engine light with p0453 code.
Thanks for using 2carpros.com!
Jan 4, 2009 at 12:53 PM
CSCOTT71
MEMBER
[quote="bluelightnin6"]Check volts at wiring. Should not exceed 4.9 volts or it will illuminate the engine light with p0453 code.
but if to high how do i fix
Jan 4, 2009 at 1:02 PM
BLUELIGHTNIN6
If volts are too high, you will need to replace the connectors on the wiring, or the wiring itself.
Jan 4, 2009 at 1:04 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
