2003 Buick Rendezvous service light on
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
CSCOTT71
yes i get it scaned and code po453 came up and i repaced pressure sensor in the tank and unhooked the battery and drove 20 miles and came back on
Jan 4, 2009 at 12:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check volts at wiring. Should not exceed 4.9 volts or it will illuminate the engine light with p0453 code.
Thanks for using 2carpros.com!
Jan 4, 2009 at 12:53 PM
CSCOTT71
[quote="bluelightnin6"]Check volts at wiring. Should not exceed 4.9 volts or it will illuminate the engine light with p0453 code.
but if to high how do i fix
Jan 4, 2009 at 1:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If volts are too high, you will need to replace the connectors on the wiring, or the wiring itself.
Jan 4, 2009 at 1:04 PM
