2003 Buick Rendezvous Replacing Driver Side mirror
2003 BUICK RENDEZVOUS
80,000 MILES • 6 CYL • AWD • AUTOMATIC
DRUCHE59
How do I remove the driver side mirror (heated)?
There is a small triangular plastic cover which I assume needs to be pried off, and then I have to get access to the power connector.
How to do that ?
Aug 4, 2009 at 1:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need a special service tool (J 38778 , door trim pad and garnish clip remover) for this repair. it is required to remove the door trim panel in order to gain access to the mirror mounting bolts and electrical connections.
Aug 4, 2009 at 4:48 AM
