2003 Buick Rendezvous Reciever drier/ compressor oil
SRWATTS98
Air Conditioning problem
2003 Buick Rendezvous 6 cyl All Wheel Drive Automatic
Q Where does the reciever drier go? Where does the oil go?
Jul 9, 2010 at 12:09 PM
HMAC300
  • 48,601 POSTS
the accumalator is the same thaing as a receiver /drier. there is a bag of desecant in the accumalator. it's right off of the evaporator on the firewall. the oil is in the system if you are adding oil get the correct type and add about an ounce of oil either in the hose or on the outlet side of the accumalator. if you add this, make sure to turn the compressor on and off so as not to do damage to the compressor.
Jul 20, 2010 at 10:26 AM
