2003 Buick Rendezvous Rear axle seal # 88996609
2003 BUICK RENDEZVOUS
CARDWELLRACING
Drive Train Axles Bearings problem
2003 Buick Rendezvous 6 cyl All Wheel Drive Automatic
I would like to know if anyone has a seal replacement for the oem seal # 88996609 which is the rear axle seal on the 2003 buick rendezvous awd this seal is very expensive from gm $67.00
Thanks Tom
Aug 26, 2009 at 4:09 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model the CX or CXL and what is your engine size in liter.
Aug 26, 2009 at 9:24 AM
CARDWELLRACING
It is a CX with a 3400 3.4L engine I do also have another question is there any other oil I can put in the differential then the Versatrak fluid
Thanks Tom
Aug 26, 2009 at 10:02 AM
IMPALASS
  • 3,112 POSTS
Hi Tom Thanks for getting back with me. As for the seal - if you are getting it for about $67 I think you are getting a good deal. I looked it up on the following web site and as you see below, it is only about $50.00 but with shipping it ends up being about $66.00. http://www.gmpartsdirect.com/
https://images.2carpros.com/forum/automotive_pictures/248015_Picture1_28.jpg
On our Cost Estimation area we list it as about $84.00 - item number 2 in the pic
https://images.2carpros.com/forum/automotive_pictures/248015_Graphic_7.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture3_37.jpg
So for the seal, yes it does seem pricy but I think compared to the other areas you are doing fine. As for the lubricant. I would use what they recommend. Yes it is pricy....very....but you don't want to void any warranties or possible recalls by using a different lubricant.
Aug 26, 2009 at 11:44 AM
IMPALASS
  • 3,112 POSTS
Also Tom, one other thing. Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recalls_29.jpg
Aug 26, 2009 at 11:46 AM
