2003 Buick Rendezvous noise only when turned
76,000 MILES • 6 CYL • AWD • AUTOMATIC
GECASE
My buick has started making a moaning kind of sound seems to be coming from the right rear tire but only when I'm turning the car to the left.First thought the tire was rubbing on something but don't see any marks and the tires are new about 8 months ago.A wheel bearing would make noise all the time wouldn't it?
Thanks
Jun 22, 2008 at 1:49 AM
DENNYP
  • 1,824 POSTS
It is most likely the rear diff pump. You should have the fluid flushed. There is a special procedure for doing this. Your local dealer should be familiar with this.
Jun 23, 2008 at 2:27 PM
