2003 Buick Rendezvous fuel pump
CRUM52
Engine Mechanical problem
2003 Buick Rendezvous 6 cyl All Wheel Drive Automatic
how to change fuel pump
Feb 28, 2010 at 6:38 AM
  • 110,248 POSTS
The fuel pump is in the fuel tank. To remove it, the tank has to be removed. Make sure to disconnect the battery before starting. After it is disconnected, remove the fuel tank and you will gain access to the top of the tank. THe fuel pump is located where the lines come from the tank.
If you have other questions, let me know.
Mar 4, 2010 at 10:36 PM
