2003 Buick Rendezvous engine ticking
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
LOUISEHOOKER
the oil has been checked, it doesn't need oil but it is ticking is the oil pump or what do you think? i am disabled and i can not aford to donate right now but i truly do need your help please thank you
Feb 1, 2009 at 8:57 AM
  • 110,248 POSTS
Hi:
I doubt that the oil pump is going bad. If the light or gauge isn't indicating a problem, chances are you just have a loose rocker arm. You can remove the valve cover to check if it is adjustable.
Let me know what you find.
Feb 16, 2009 at 10:46 AM
