2003 Buick Rendezvous water leak inside the car
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
PREACHER1611
Working on this car for a friend and the a/c condensate is pooling inside the car under the drivers feet. I can not find a drain tube of any kind(assume it is clogged). Buick dealership said it is in engine compartment on the fire wall behind some type of panel. All i see is 2 rubber grommets with nothing behind them. can you help me find this mysterious clogged tube? never used this website before and don't mind donating if I can get help.
Mar 28, 2008 at 11:15 AM
  • 55,682 POSTS
Hey Preacher1611,
Models:
(01, 02, 03, 04 Buick Rendezvous/Pontiac Aztek)
This 2001 through 2004 model year Rendezvous and Aztek evaporator case water intrusion message is being sent to all Buick and Pontiac dealers. Engineering has identified a potential water leak path from the evaporator case drain provision on all 2001 through 2004 Buick Rendezvous and Pontiac Aztek models.
Under certain high humidity and high ambient temperatures, when the vehicle is being driven for extended period of times using a very low blower speed, the condensation can reach the vehicle and wet the front carpeting. If the owners encounter this condition and subsequent water testing shows that there is no other cause for the water leak, an extension elbow should be installed to reduce the likelihood of any reoccurrence of water entry.
The part number recommended is 22542866. This part is also used on other General Motors products. Our current plan is to utilize this part in production as soon as possible and a bulletin is planned which will contain the breakpoints when the production changes to use the new elbow.
But before going through all of that I would take an air hose and blow backwards through the condensation tube to remove any obstructions.
Here is what one looks like in this article.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Toward the bottom of the guide.
I can't find any pictures of yours for you. You might have to get under the vehicle to find it. It will be on the firewall, in the middle or on the passenger side.
Please let us know happens so it will help others.
Best, Ken
Nov 29, 2016 at 10:32 AM
