2003 Buick Rendezvous Air conditioning controls
68,450 MILES • 6 CYL • FWD • AUTOMATIC
TOMLIGHT
I can not change the temperature on the passenger side of the car, the fan blows 3x harder on the passeneger side and there is no difference in winter or summer or vent selection. The air on the passenger side is always cold. Not A/C cold but cold. The temperature adjustments work fine for the drivers side, but the passeneger side has no effect. I assume there is an electronic control somewhere that this slide is actuatiing, but where is it and am I looking for the right thing. Any Information would be helpful.
Thanks Tom
Dec 17, 2007 at 4:00 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to remove some covers under the dash so you can verify that the actuators for the doors are moving when temps and vents are selected. If none of them move with just the p/s side controls, it could be the control head, but check the door operation first. As far as airflow goes, have you changed the cabin filter yet?
Dec 17, 2007 at 11:58 PM
