2003 Buick Rendezvous
JOSEPH FRANK
hi can you give me advice on changing regulator motor on drivers side front? thanks joey
Jul 22, 2010 at 2:52 AM
GMTECH
  • 537 POSTS
What is your issue? Is the motor seized? It is not a difficult job, but you have to be carefull when removing the door panel as the type of retainer used can be stubborn, so you don't want to break the panel when you are removing it. it is common for the sash and guide to break which will prevent the operation of the window. Advice, take it apart and have a look.
Oct 25, 2010 at 12:42 AM
