AWD light on
125,000 MILES • 4 CYL • AWD • AUTOMATIC
DEBDAVIS379
This am my light for AWD came on also the break is letting up and making it stop after the break has been pushed and you have to pump the breaks if this happens. What happen if the AWD is disabled.
May 5, 2010 at 10:18 PM
BMRFIXIT
  • 19,053 POSTS
check for codes
check for ABS codes and suspect a wheel bearing
check wheel bearings and ABS connectors at each tire by the axle
May 5, 2010 at 11:13 PM
