2002 Buick Rendezvous WHEELS NOISE
92,458 MILES • 6 CYL • 4WD • AUTOMATIC
BJEALLEN
I hit a small hole and begain to hear a loud noise so I had it checked and was told to replace the tire and I did. I still hear the noise it even more louder. at 10 -20 miles it loud but not that loud the more I in crease speed the louder the moise gets. What can it be and what should I do now.
May 7, 2008 at 9:23 AM
DENNYP
  • 1,824 POSTS
sounds like a bad hub on the front end. It is probably on the side that you hit the hole with. Drive it and turn the wheel side to side to see if the noise changes or goes away.
May 16, 2008 at 3:11 PM
