2002 Buick Rendezvous traction control
2002 BUICK RENDEZVOUS
TPERRY1215
Tires and Wheels problem
2002 Buick Rendezvous Two Wheel Drive Automatic
Im not sure if my vehicle is all wheel drive or not, i had it look at once by midas and they said it was 2wheel drive with the ability of all wheel drive. Anyways my buick has traction control that only kicks in when it needs to (and their is no way to turn it on or off) with this snow i have been slipping and it says on the dash that it is kicking on like it should be but its not working because im not going anywhere and whenever it kicked on before it would get me thru it, so im not sure what could be wrong with it....Recently before winter started i changed my rotors and put all wheel drive rotors on it instead of 2wheel drive. Could this be the problem
Feb 26, 2010 at 11:55 PM
  • 110,244 POSTS
Are there any other lights on? Also, I need you to check if it is 4wd. Look under the rear of the vehicle. Are there axles going to the rear wheels?
Mar 4, 2010 at 10:55 PM
