2002 Buick Rendezvous Master Power Window Switch
61,000 MILES • 6 CYL • AWD • AUTOMATIC
SAPELZIN
The driver window switch (AUTO) no longer operates normally to move the window up. Inserting a screwdriver under the switch and forcing it does move the window up. There seems to be poor contact, or the switch is worn.
Are the window switches in the master switch interchangeable? i.e. can I change a rear window switch with the driver window switch?
If I need to purchase a replacement master, what other GM models have a compatible master switch?
Thank you
Apr 12, 2010 at 10:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no, the master switch must be replaced with another master switch. may be able to find cheap online at sites like ebay.com or car-parts.com. also search local salvage yards. brand new the master switch is around $100..
Apr 24, 2010 at 6:19 PM
