2002 Buick Rendezvous lights
12,600 MILES • 6 CYL • AWD • AUTOMATIC
ALANCATHY
  • 20 POSTS
when I start my truck the headlights come on but,
when I turn the motor off the lights stay on and not go off even after hours of sitting,
thanks,
Alan
Feb 1, 2008 at 4:59 AM
2CARPRO JACK
  • 11,533 POSTS
This has auto headlamps? These are the headlights we are talking about and not the DRL's? There are relays in the underhood fuse center, try swapping out the A/C relay for the headlight relay or the DRL relay depending on which is staying on.If it fixes it, you have a bad relay, if not get back to me, might be a problem with the BCM ( Body Control Module)
Feb 2, 2008 at 12:51 AM
ALANCATHY
  • 20 POSTS
I Swap out the relays and lights still on, All the lights not just headlights, Even when I disconnect tne light
switch, They are still on, After I disconnect the battery they go out, and come back on when engine is started again, Also I have to press the key remote switch before it will start does this go together,
Thanks,
Alan
Feb 2, 2008 at 4:42 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the BCM is having a problem. Might want to have it scanned for any codes that will help us figure this out
Feb 3, 2008 at 12:24 AM
