2002 Buick Rendezvous FUEL PUMP REPLACED
DBOWENS65
Engine Performance problem
2002 Buick Rendezvous 6 cyl Front Wheel Drive Automatic 145K miles
I JUST REPLACED THE FUEL PUMP... IT'S PUMPING GAS BUT THE VEHICLE WONT START UP (NOT GETTING TO THE ENGINE)
WHAT COULD BE CAUSING THIS PROBLEM?
Dec 21, 2009 at 6:54 AM
  • 75,988 POSTS
Check the fuel filter if it's clogged up and check the injectors if they are pulsing.
Dec 22, 2009 at 8:00 PM
DBOWENS65
THANK YOU FOR YOUR RESPONSE REGARDING MY 2002 BUICK RENDEVOUS... YOU INDICATED TO CHECK THE FUEL FILTER TO SEE IF ITS CLOGGED.. WE REPLACED THE FUEL FILTER ALREADY WITH A NEW ONE. YOU SAY CHECK THE INJECTORS.... FUEL INJECTORE?? WHERE ARE THESE LOCATED? SHOULD I ATTEMPT TO PUT DRY GAS IN THE TANK? I REALLY NEED MY VEHICLE. WITH THE HOLIDAYS , MONEY HAS BEEN TIGHT...
AGAIN...
THANK YOU !!
Dec 27, 2009 at 1:29 AM
