2002 Buick Rendezvous Car not accelerating
110,000 MILES • 6 CYL • AWD • AUTOMATIC
ASAXENA
My car starts with no problem , but after several minutes of drive it will stop accelerating. I push the gas and RPM go up but car does not move. Engine temp is normal and running. If I stop and shut off the car and restart it in several minutes it will again start to move but then after several miles it will again stop accelerating when I press the gas pedal. What could the problem be?
Apr 30, 2009 at 1:45 AM
  • 75,988 POSTS
Do you have a check engine light? Sounds like the transmiision is slipping. Have you ever had the transmission serviced?
Apr 30, 2009 at 1:49 AM
ASAXENA
Yes I do have the light on. I had Autozone check the code and it was something to do with the Trans code (do not remember the code). I had a transmission FLUSH done and the light had gone away but it is back again. What do think the next steps are and how much $$$?
Apr 30, 2009 at 2:04 AM
  • 75,988 POSTS
You need to have the code/s pulled again-this thing can be a sensor or a shifting solenoid etc-
Apr 30, 2009 at 8:36 AM
