2002 Buick Rendezvous All Wheel Drive Disable
134,000 MILES • 6 CYL • AWD • AUTOMATIC
BRENTPACKER
I received the above warning light. I took it to my mechanic and he replaced the fluid in the rear differential, but the warning light is still on.
Any idea
Mar 2, 2009 at 4:29 AM
AMKK_WOODRUFF
If your anti-lock brake warning light is engaged along with your awd disabled warning light, you will want to check your rear shocks and bearings. I have this problem right now. If there is more than (I believe) 4/1000 of give it will trigger this reaction. Give this a try. Hope it helps. (By the way----the cost of replacing the rear passenger bearing will be around $95--not including labor)
Mar 17, 2009 at 11:41 AM
JFELDNER
