2002 Buick Rendezvous Air Condition works Intermittently
2002 BUICK RENDEZVOUS
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
PUNEET_NEHRA
My 2002 Buick Rendezvous AC works intemittently. It works only sometimes, no exact behavior observed, initially I was observing that it works only in the evenings when temperature outside is low, but yesterday observed it worked during day time also once. There is no guaranty, that switching of the car and start it again, that AC will work or not. Any suggestions.
May 2, 2009 at 9:07 AM
DOCFIXIT
  • 18,828 POSTS
Have the system charge checked
May 3, 2009 at 5:52 AM
PUNEET_NEHRA
I think the answer to your question is yes. I noticed none( two) of the fans near radiator work when I start the car under the hood, though internal blower works fine. Freon status is ok, I got it checked by mechanic today, he suspects it to be a electronic issue, may be a fuse, but he couldn't check that. Hope this helps.
May 3, 2009 at 3:07 PM
DOCFIXIT
  • 18,828 POSTS
See if cooling fans come on with AC on. If not then high side switch is cutting Ac comp off to protect. Check fuses and fan relay underhood in junction box.
May 4, 2009 at 5:10 AM
