Good spark, Steady 40 Lbs working gas presasure, all vacuum lines are new and vacuum checked, intake manifold Gasket vacuum checked, strong cranking, [b:23e09733c9]Cam and Crank shaft sensors have not been checked, [/b:23e09733c9]so is there any reason that would cause the engine not to start. [u:23e09733c9]History[/u:23e09733c9], the engine did start and wouldren for 30 seconds and cut off but the gas pressure would remain steady at 40 lbs. that caused the changing of all vacuum lines and testing. The engine than started and ran perfectly for over 10 min and was turned off assuming that it was fixed. The next day nothing, no pop, strong cranking, strong spark, and no start, nothing. What could cause the engine not to start ? :( :?[/b]
Mar 26, 2006 at 2:47 PM
