Power Steering Problem
BUICK REGAL
RRG
I have a 1998 Buick Regal LS with 113500 miles on it. It has an automatic transmission with front wheel drive. I made a hard right turn to back out of a cul de sac. I then had an immediate problem with the power steering not working when the wheel was turned to the left. I checked the fluid and I did add some, but...turning the wheel right and left to bleed possible air bubbles hasn't worked. Could I have I put the steering wheel position sensor out of alignment? I don't want to remove the pump or the steering rack just to go on an expensive fishing expedition to find the problem.
Sep 7, 2007 at 1:17 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
When you hold a steering wheel at the stop, for too long, wich at the high pressure involved, seals take a beating quickly, check your pump first, they seem to get ruined before outlying parts....
Sep 7, 2007 at 3:27 PM
