No headlights or tail lights
RLEITCH1
I have an '89 Regal Custom, 200K miles ans 3.1 Engine. I have already replaced the headlight switch. Other than the wiring, is there anything else that could cause the problem?
Aug 15, 2007 at 4:18 AM
MIKE H R
  • 3,094 POSTS
check all the fuses. The tailights should be on the fuse panel, while the headlight fuses are under the hood, just because a fuse looks good sometimes they are bad and should be checked.
Aug 15, 2007 at 11:27 AM
