no digital odometer
BILLJACK215
I Have a 1997 Buick Regal LS. My digital odometer is out completely. The speedometer is working . All of the fuse are fine . What should I check ? Thanks .
Jun 1, 2007 at 6:48 AM
AVIONIK99
You will need to remove the cluster and send it off for repair or replace it with one from ebay or some other store. Unless your savy with electronics then you might be able to get away wiith replacing an IC chip or module
Dave
Jul 27, 2007 at 4:53 PM
