Buick Regal heater light
MIGHTBEANANGEL18
Make: Buick Model: Regal GS Year: 1998 Mileage: 65,000 Engine size: V6. I just bought a 1998 Buick Regal and the heater climate control [img:bdee125784]http://www.2carpros.com/forum/automotive_pictures/108247_climate_control__circled_1.jpg[/img:bdee125784]light is out. Without it I cannot tell the temp and settings the heater is on. I looked in the manual and that was no help. How can I fix the light?
Oct 16, 2007 at 2:07 PM
FISHERMAN
  • 937 POSTS
Hello !! Looks to me like you have a blown fuse.. Check all of them. the fuse box its located behind a panel in the glove box under the dash or under a cover in the kick panel.. Let us Know if that solve your problem ! Good Luck! (BTW Thanks a lot for your Donation !! )
Oct 16, 2007 at 3:25 PM
MIGHTBEANANGEL18
Hello !! Looks to me like you have a blown fuse.. Check all of them. the fuse box its located behind a panel in the glove box under the dash or under a cover in the kick panel.. Let us Know if that solve your problem ! Good Luck! (BTW Thanks a lot for your Donation !! )[/quote:c7a6b6aeca] It's not a fuse. I checked the manual and the fuse box. No blown fuses and nothing even similar listed in manual.
Oct 24, 2007 at 6:28 PM
