1994 Buick Regal Coolant Leak
MLEMON
My Regal was leaking coolant from somewhere other than the radiator or reservoir. it looks like it was coming from what I later realized was the water pump. Does taht mean my water pump is bad? My serpentine belt got wet, slipped off and shredded. And before the belt shredded, I noticed my radiator fans weren't spinning. Are they suppose to spin all the time?
Feb 6, 2007 at 3:22 AM
CHEVY22
  • 1,375 POSTS
fans dont spin all of the time ,and if the water pump is leaking it is bad ,
when replacing the water pump i would recommend replacing the serpentine belt tensioner and of course you need a belt , it almost sounds like the water pump locked up , try and move the pulley by hand
jim
Feb 17, 2007 at 7:36 AM
Suggested Repair
A leaking water pump is bad and should be replaced; also replace the serpentine belt and belt tensioner. Try turning the water pump pulley by hand, since it may have locked up. Radiator fans are not supposed to run all the time.
Conversation Summary
The owner of a 1994 Buick Regal reported a coolant leak that appeared to come from the water pump, a wet serpentine belt that slipped off and shredded, and radiator fans that were not spinning. The expert said fans do not run constantly, a leaking water pump is bad, and the pump, belt, and tensioner should be replaced. The expert also suggested checking whether the pulley can be turned by hand in case the pump locked up.
