2004 Buick Regal Shifting Problem
125,000 MILES • 6 CYL • FWD • AUTOMATIC
MISTERP999
When the weather gets cold, I cannot move the gear shift lever. The colder it gets, the more difficult it is to move. The shift lever is on the steering wheel column. Summer time, no problem.
In winter, if and when I get the lever moved to drive, for example, the car shifts gears while driving without any problems.
Just can't hardly move the lever.
Any ideas?
Nov 22, 2009 at 10:52 PM
  • 110,251 POSTS
I would recommend starting by lubericating the linkage. If you look under the hood on the driver's side, you will see where it comes through the firewall and to the transmission. Try spraying some WD40 on any joints or pivit points and cables.
Let me know if it helps.
Nov 24, 2009 at 12:04 AM
