2004 Buick Regal Regal stalls when applying brakes
2004 BUICK REGAL
37,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEBERT
My 2004 Buick Regal with 37000 miles stalls occasionally when applying the brakes. The car will starts back up and runs fine. There is no indication of it quiting. We have replace the battery and the fuel filter. The dealer could not find codes and has no idea what could be causing it to stall. They want to flush the fuel system, replace the ignition switch and the fuel pump. It is when the vehicle is slowing down. It quit doing it when I originally posted, but it has started again.
Jan 17, 2008 at 12:48 AM
2CARPRO JACK
  • 11,533 POSTS
Do you mean it stalls when coming up to a light or when you apply the brakes to put it in gear? Could have a slow/sticky ISC motor (idle speed control).
Jan 23, 2008 at 11:50 PM
